Moin,
Mein Wetter widget funktioniert nicht mehr
Hello,
My weather widget is not working anymore
gt
Try YR
Oh and you can try this too:
goto settings -> apps & notifications -> app info -> weather -> storage -> clear cache & clear data -> restart device
You should be able to type weather into the Google search box widget. Choose the word weather from the results. On the top right corner of the resulting screen should be a menu that offers you an option to save the weather as a shortcut on your home screen. Otherwise there are other weather widgets available at the Google Play Store.
