How to setup a vpn?
Easiest way:
Install a VPN app like OpenVPN and read a howto.
There is a rich choice:
You can setup VPN for your device.
VPN phonewide is done by setting it up in settings (search for VPN) , remeber to install a VPN app first.
You can choose to set up VPN just for your browser.
Example: I have a VPN through my Raspberry and I have set Firefox on my phone to use it. When the blocking is too strict I use Chrome which does not go through a VPN.
VPN is a smart choice when you use public WiFi. (your connection will be encrypted)
The smarter choice is to never use public WiFi and only connect through mobile internet.
Hey! Setting up a VPN seems daunting, but it's pretty straightforward. The exact steps will depend on the VPN provider you choose, but generally, you must sign up for a plan and then download and install the VPN software.
If you're looking for a reliable VPN provider, check out ishosting. They offer affordable VPS plans that you can use to set up your own VPN, as well as pre-configured VPN plans if you prefer an easier setup process.
