Проблема заключается в том что после работы с приложениями я выхожу на рабочий стол и там вижу эти приложения полупрозрачные через экран рабочего стола, в основном в верхней части экрана и слевой стороны. (на скриншотах эта проблема не видна) Как это устранить?
The problem is that after working with applications, I go to the desktop and there I see these applications translucent through the desktop screen, mainly in the upper part of the screen and on the left side. (in the screenshots this problem is not visible) How to eliminate it?
gt
Oops, can't read it
Would you be so kind to translate your question into English.
You can use translate.google.com
I have a transparent desktop, through the main display theme visible ,recently closed applications. They disappear after a while. And new ones appear instead. (on screenshots this effect is not visible)
