Hi, I'm Richard and just checked that there was an update and since there was an formula one team changing tires of a car as a picture in the description I went ahead and decided to update it I just thought it would be the fastest update ever. Now, after downloading it and installing it the phone restarted corectly but once in the desktop all the apps ono by one started crashing from messages apps to home desktop apps and like that one after the other my phone looked like a stroboscope so I decided to turn it Off and On again and the result now is that i'm stuck at the White Xperia Logo screen. and can't even turn it off. I'm scared the battery will end and I will not be able to turn it on again (BTW Battery was 100% 10 mins ago.) also scared it will overheat or burn the battery here.I Need a Sony Doctor here please.
btw also my phone is conected to pc via usb and Sony Companion doesn't seem to find it also tried to repair phone via Companion and but they ask to turn off the phone wich is impossible unless there is a Trick I do not know of Help! Thanks bye.
-RESOLVED-
The Trick:
By pressing Power On/Off button and volume up until 3 vibrations(IT TURNS THE PHONE OFF).
Turned it back On successfully this time.
At least it is documented now.
-Resolved-
