x
Sony Xperia X Screen
Tetiana1
Visitor
When I make a call in phone (or messanger) the screen became black and I can not fix it until someone (in the other side) finish the call. I can not use the phone during the call at all. And when I'm calling someone,and nobody pick up the phone, I also can not finish the call, because the screen stays black, as I said. Can you please help me?
5 REPLIES 5
profile.country.GB.title
Uliwooly
Expert
@Tetiana
Does your phone has a protective case, film and/or glass?
Tetiana1
Visitor
Yes, I have a glass. But when I'm calling in Viber everything is working
Uliwooly
Expert
@Tetiana
remove it > clean the proximity sensor > report back.
Tetiana1
Visitor
I can't remove it, it's spesial glas... And when I use viber everything works...
Uliwooly
Expert
@Tetiana
Settings > about phone > diagnostics > test the proximity sensor.
Keep in mind that if you send it in, they will remove the glass.
Also, test it in >>> safe mode
