My Xperia X is stuck in a constant boot up loop. Walked upstairs in my house and there it was all hot and going through the boot up process. The phone is brand new and it's very disappointing this is happening. During the boot up process it gets stuck on the screen that says "xperia" and then the screen goes purple and it starts all over again.
Any help is greatly appreciated.
Hi @EVB87, welcome to the community
Try these steps one after the other. Check whether the problem was solved after each step, before trying the next one.
Im having the same boot problem but I cannot repair it with companion, I have been already 4 hours waiting for it to initialyze
If your device is not recognised by Xperia Companion then tick unknown device or Smartwatch 3
Probably it will find your device then.
I ended up having to send the phone to a facility in Chicago. They fixed it, not sure how.
