I'd like to know if there's a way of prevent screen lock when the Sony Clock app is running the timer or countdown function. If there isn't, I'd like to suggest this feature. Furthermore, I suggest a fullscreen mode. I'd like you guys think about it because I like to use official apps on my Xperia.
Thank you in advance.
I'll escalate this but contact Sony with your suggestion >>> Local support
BTW you should be able to see the timer with the screen locked.
