- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
March 2017
March 2017
Soft and hard reset
Hot had the phone two weeks yet and on two separate occasions it has had issues. Within 48 hours it needed a soft restart to switch on and this morning it has completed a hard reset to factory settings. Is this common?
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
March 2017
March 2017
Hello, @Dmc7678
This might be a software issue, you should consider performing a software repair using Xperia Companion. This will do a clean installation of the latest firmware and will also wipe your internal memory. Follow the steps given in the blue link, do not connect your phone until prompted to press volume down while plugging USB cable.
Don't forget to save your important data through backup using Xperia Companion (don't backup apps and settings).
