SmartConnect (after the smartphone was upgraded to 8.0 Oreo) stopped executing the command. When I connected the NFC to the SBH-20 headset, I turned off ClearAudio +, so when the headset was turned off the function was turned on. So I guess that the OS does not work correctly in some place. It was also tested on another device with a similar circuit. The result is the same. Or the application already without support on Android 8.0?
Having similar issues. Connect headset - Smart Connect not detecting it, or sometimes starts Soundclound instead of Music app.
I read a local forum and together with other users we decided that the program simply was not adapted to 8.0
Same issue here. Program does some actions, but not all. In my case play music.
yeah, it seems not working in Oreo 8.0, mine too is missing...
