when booting, after the xperia screen i get a white screen with three dots "..." then it shuts off very quickly. xperia companion wont work; it just says the device is locked. any ideas?
When did this started happening?
what if you turn off the phone > run XC > follow the steps with the phone off
i got XC to work but unfortunately it doesn't fix it.
previous owner says the problem started after replacing the screen himself. since the display seems to work is it likely a problem with the motherboard?
