@PlayStation_Guy wrote:
After Nougat 7.0 update, phone will not mount SD Card. SD Card usage is restricted.
Did you tried remove and add again SD card or to format it (do back up before format, coz format will erase your files)?
Sometimes simple things helping to solve problems like this one
Yes, formatted both EXFAT and NTFS. Did the removal process also.
And still can't mount?
Factory reset phone, back to normal (mostly)! Phone notification there was a SD card installed and asked to format it. For the most part, I can access the card, store and view music, photos, and videos. Thanks to those assisting.
Anytime if help is useful
