Good morning.
I bought an Aukey Quick Charge 3 charger, and I'm charging the phone during the night. I think that the feature "battery care" is not working properly, because I woke up at 4:00 am, and the phone was already at 100, when according to the "battery care" feature, it should reach 100% when I disconnect the phone at 7:00, the hour when I usually wake up.
Anyone noticed this?
Did the battery care pop up when you connect the charger?
Did this happen more than once?
@Alanslade: the battery care only works when the phone is turned on.
when you connect the charger it should give you the time estimated ( as you have already stated), but leave the device turned on, do not power it down.
@Alanslade wrote:
Seriously? Only when it's on?
I always charged my phones when they are off to prevent battery consumption.
So this feature is a little useless I think
In my experience phones consume a lot of battery powering down and up again... you are better off putting your phone on "flight mode" during nighttime to save battery and disable it in the morning.
