Dear all,
I'm having a small bug. Proximity sensor is blinking while data transfer is on. It happens only with mobile data. I tried safe mode, truning of adaptive brightness, safe mode etc. Nothing worked. And it drains alot of battery.
So many people are having this problem. I already posted in another thread. But no one seems to care. Please look into it. Its really annoying.
you mean the red thing near the upper speaker?
can you show a video of it?
as answered in the previous threads, it is not actually blinking it only appears to be because it is a low energy infrared proximity sensor. so it wont really drain you battery .
if you are talking about the led light, it wont be possible to disable it without third party app
No it's actually blinking exactly while data transfer is on. I know about low battery warning. I'll try to record a video and put the link here today. Then see for yourself. I'm really frustrated by this.
@nolramlb This is the video link as you asked.See it and reply me what to do.
@nolramlb wrote:you mean the red thing near the upper speaker?
