Hi there,
I have updated to Oreo two days ago.
Things from the previous configuration have changed.
Whatsapp notifies me with pop up messages (from the top of the screen, taking like 25% of it). It is very annoying. I can't get rid of it.
Also, I set the settings to no vibration, but it changes by itself back to vibration. I changed settings both in whatsapp and the phone notifications but it doesn't work
It took me a while to have the phone working as I wanted and now with the update, everything is messed up.
What can I do?
That's standard oreo notifications
As for the vibrate notification, check each app notification settings.
So I have to accept that the notifications will be popup from the top-25% always? I don't think this is normal. When I got the phone I had the same, but finally got rid of them.
About vibration. Yes, I changed the settings (in the app) but it changes automatically back. Without me touching anything. That's not normal
cheers
Hi, try this:
Settings, notifications, info of the aplications, Whatsapp, notifications, chats. You can choose this posibilities on the importance level: Sound and appear on screen, only sound or nothing.
Sorry for my bad english.
I did that. no sound, no popup. in the level section
but it changes
the point is other apps also have these popups notifications
I just don't want them
What can I do?
I'm willing to go to the previous version of Android
So I don't know what to tell you, I installed Oreo 34.4.A.2.19 in Spain yesterday and doing that doesn't give me any problem ...
also from the settings of the Whatsapp itself there is an option to allow pop-up window to be disabled, in WhatsApp, settings, notifications, allow pop-up window
I guess you've already tried it, but maybe if you uninstall WhatsApp and reinstall it ?, or make a software repair with Xperia Companion.
But what happens to you is not normal, because I do not have problems.
I have the exact same problem. I actually don't mind the whatsapp notifications in the top bar but I do not want my phone to vibrate for whatsapp in any way. I have now turned off all notifications for whatsapp because I don't know how else to fix it. All was fine before the latest oreo update...... , I HATE it when a software updates messes with your settings.
