Tengo un pequeño problema con el lector de huella de mi Sony Xperia x cada ves que quiero registrar la huella me da fallo y me pide que libere espacio y lo intente de nuevo ya lo hice y también lo reinicie de fábrica que puedo hacer
I have a small problem with the fingerprint reader of my Sony Xperia x every time I want to register the fingerprint it gives me fault and asks me to free up space and try again I already did it and also restart it from the factory that I can do
-GT
Just a wild guess.
Goto settings->apps & notifications-> App info
Tap the 3 dots in the upper right corner->show system
Find Fingerprint ASM -> force stop then restart
(I noticed no change whatever so I guess it doesn't help you)
Other choice
Restart in Safe Mode (switch off with the power button and then long-press the restart button)
Does the fingerprint act as expected in safe mode?
Did you clean your fingerprint sensor?
