Problem with Locked Screen
When the screen is locked, the notifier is not displayed, the screen is constantly scurf
Проблема при заблокированном экране
При заблокированном экране не высвечивается уведомлентя, экран постоянно чергыц
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Could you elaborate and maybe provide some screenshots?
