- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
No volte available after 7.1.1
There is no volte toggle avaliable after, 7.1.1 update i even tried the *#*#4636*#*# method but no use. Any one plz help me
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No VoLTE activation option
Online reviews and specs on this phone state that this phone is VoLTE provisioned, but I am not able to use that feature. Reading through the forum on related topic, the solution I get is to make sure that a VoLTE active sim card, be inserted.. Well, as per the screenshot, that's a VoLTE sim card inserted and still I can't find the option to enable VoLTE. I thought Oreo Update will bring this feature but it didn't. Any other method to activate this feature on my phone that doesn't need an "operator firmware" that I honestly do not understand???
Device: Xperia X (F5122) Running on Android 8.0.0 Build Number: 34.4.A.0.364
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
From the Xperia X manual:
Pay attention to the 1. remark
And don't forget to read the very last sentence.
Android™ 8.0 To enable VoLTE
- Make sure your specific Xperia™ device model and network subscription support VoLTE.
- Find and tap Settings > Network & Internet > Mobile network > Preferred network type > LTE or 4G (preferred)/3G/GSM.
- Tap the switch beside Enable VoLTE to activate VoLTE. If Enable VoLTE isn't available, contact your network operator.
Android™ 5.0, 5.1, 6.0, 7.0, 7.1 or 7.1.1 To enable VoLTE
- Find and tap Settings > More > Mobile networks > Preferred network type > LTE or 4G (preferred)/3G/GSM.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Does my Xperia x supports volte
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Your Xperia does, that's for sure.
Question is if your provider supports it.
Use Google to find out about the details
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I to have same problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
On my phone you can’t enable the rest of the functions....
What can I do to turn Volte on ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I am also facing the same problem. i have xperia x compact with anroid 7.1.1.
model - F5321
BUILD - 34.3.A.0.252
customization-1305-2001_R2D.
It does not support VoLTE.. Volte provision is turned off, it slides to on but doesnt stay.
All phone manufacturer are giving software update for VoLTE , do not understand why Sony is not paying any attention. it would be a simple fix at their end. for us its a huge problem. In India its open carrier, they do not provide any firmware. reliance jio doesnt work without voLTE.. I was a huge fan of Sony , unfortunately have to give up, worthless support and forum, all you do is lock down the thread without providing any solution.
we are just wasting hard earned money for those who do not care about its customer.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'm having the exact problem and my carrier has told me that it's my cell phone issue but i know it's not because nothing ever such happened which could break my phone and cause this issue.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Same here. Same SIM inside my old iPhone SE has VoLTE enabled. Not in the Sony. My carrier says the same: if the device is VoLTE enabled, it should be automatically on from their side.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I am using Xperia X Compact...US purchased but flashed UK firmware 7.1.1 for fingerprint reader. I am unable to use VOLTE at the moment.
Can you please help me on this? Which firmware are you using - UK OR US? How is this device holding signals with JIO sim as mine is pretty bad. Have you tried with Airtel too?
I can't enable VOLTE flag as you have advised.
Many Thanks in advance.
