Hello,
i got a problem with my new xperia x performance.
i cant make an update to android 8.0.
xperia companion says the software is up to date and no ota update
sry for the bad english
Then go to Sony and check with your IMEI #
If it should have a more recent update and you cannot get it the do the Software Repair again.
This time switch off your phone (charged > 80%)
After starting the software repair menu in Xperia Companion you can tick a box where it says: Device cannot be recognised or is a smart watch.
Do so and continue.
Hope this helps you.
PS
On this forum go Information and FAQ.
Take care that you do make a proper backup.
Make separate backups from your messenger apps like Signal and WhatApp from within the settings in these apps.
Hi @JohnnySplash,
Can you please get back to me in a private message with your IMEI number?
Thank you.
