For quite a while now (maybe 2 months), I've been getting no alert sounds when using the SMS messaging app that came installed on my phone. No sounds for incoming messages, and no sounds for outgoing messages. I've read numerous threads on the subject, and have tried many things to get the sounds back. These have included checking the sound settings (checking the media volume), as well as trying different notification sounds.
As well, I've tried clearing the data and cache in the messaging app, then rebooting the phone, but none of this has fixed the problem.
It's very frustrating , as I basically miss all of my incoming messages unless I constantly look at my phone to check if there's a new one.
Hopefully someone has a solution for me.
Thanks
I had no Sound at all. The only solution was to send sms via Messenger.
This was precisely the problem I was having and your solution worked perfectly. Although i have no idea how that was turned off in the first place.... thanks
