Night mode
Please tell me how to turn on the xperia x on Sony, or else it's called a blue light filter, I can not find it, Samsung has it, Apple has it, but I do not.
Ночной режимСкажите пожалуйста, как на Sony xperia x включить ночной режим,или как ещё его называют, фильтр синего света,я не могу его найти, на Samsung есть, на Apple есть, а у меня нет.
No chance with Sony OS.
You have to install an app to have that.
Unfortunately, it's not available.
Which really is a shame.
It was one of the most voted feature on Concept, had great implementation.
In days we use phones more and more throughout the day, this feature should be mandatory.
Third party apps are(not) a solution. The way they work is different and not nearly as good as Night mode when it was available on Concept. From my POV this can't be easily justified since Concept showed it runs more than well.
I think @schetz that your hope for a change will be fulfilled shortly.
First there was the message that it would not be present.
Then there was a message that the wish to have it was known to the developers.
Now it's already present in XZ2 !
So who knows what devices will be next.
@Strampke I appreciate your optimism, but I wouldn't use the word "already" correlated to XZ2 .
That one is late to the party in this regard.
Also a bit that's missing here on forum are discussions like these, about missing features to be added so to speak. Better aim to fix and improve,not just the former.
That goes in line with you mentioning : "Then there was a message that the wish to have it was known to the developers." So, if true, that confirms above.
