Hello, I checked my battery usage earlier and almost 50% of power had gone to the MyExperia app. Gps was disabled all that time and I should have the latest software. New phone, I updated everything. I disabled the service now and hopefully that will fix it. Just wanted you to know that there might be a bug somewhere.
Hi @xperiauser21, I'm sorry to hear that.
Do you mean that you experience that the MyXperia application is using a lot of battery in your phone after updating to Android 7.0?
I would recommend that you disable the MyXperia service > charge your phone to 100% and use it as normal down to 5% and see if you notice any difference in the battery usage.
To disable the service go to Settings > Lock screen & security > Protection by My Xperia > Deactivate.
I'm sorry If I misunderstood your question!
