hi all,
I am facing problem to connect through Mobile data, I can connect when I restart my device but after few hours or a day it can't connect when trying to connect it, it means settings/config is correct but there is something else, how to figure it out or solve the problem?
regards
You might try a settings-> system->reset->reset network settings
