Sony xperia x. It supports mirroulink ???? On the phone in connection says mirroulink ??? And if it is not. Is there any solution with these new cellphones ????
Hi @Ezeqjielom,
MirrorLink is supported by Xperia X. You can find it in Settings > More > Device connection > MirrorLink.
Let me know if you have any further questions about this!
also xperia x dual sim ?
Except for dual SIM, other specs are practically the same, so, dual supports too.
so i can connect xperia x with cars that support mirrorlink, like z series ?
