Good day. I have a problem with my Xperia X F5122 mobile phone. It's not detect the SD card. After turning on no show up that "New SD card detected". In the storage only the Internal Storage is avaliable.
I tried to use many SD card but nothing. Formating doesn't solve the problem. I tried to repair the software with the Xperia Companion but nothing... Can anybody help me? Thanks.
EDIT: I just found the problem. It was contact problem in the Memory Card tray.
How did you clean the contacts?
Compressed air, cotton bud?
Clean inside or just the SD card?
I put a little slice of paper in the tray under the memory card. It raised up the memory card. A homemade "masterpiece" but work 😁
Sorry for late reply...
