👋, I accidentally removed Media Control app and now navigation buttons look differently. How can I restore it? Please help.
Is different a big problem?
If not then leave it as it is.
A factory reset will restore everything, however all your data will be lost.
First backup.
Yes, I know that reset would restore everything. My question was how to restore that specific app. I think, it was Media Control, but I don't see it in the list of soft from Sony...
When you restore using Google you will have a choice to restore everything.
If you don't you will be offered the choice per app which apps you want to restore.
