hi..if i want send an sms to 20 people how i can do? i don't see any checkbox for multiple selection when i chose number.
Second if i want delete some call or missed call how i can do that? i'm new with android and sony...with my old lumia that operations was really really simple...
Thanks!
Hello @lollodo86 and welcome to the community!
- For multiple recipients: when you are composing a message there will be an icon on the top right corner (an avatar with + icon), use it to add recipients one by one.
- To delete a call log entry: tap on the entry you want to delete, choose "Call details", and there will be an icon on the top right corner (bin icon).
nk you very much!
for send sms i can only select contacts one by one?
Yes and no! If you're using the stock messaging app pre-installed on your Xperia, you'll have to choose them one by one. But you can always find 3rd party messaging apps on Google Play store that support multiple selections of contacts.
