So yesterday my sim-card was locked and now when I got to open the phone again today it has trouble creating a hotspot. My computer says it is connected but has limited rights.
My phone says the hotspot is on, but there's somekind of error creating the hotspot.
Anyone else with this problem? The usb-shared connection works fine.
@Crashx try changing the security from WPA2 PSK to NONE and check if your laptop can connect, if it does connect and has internet then the problem is with your computer's wireless adapter, not the X Compact.
Hi @Crashx, welcome to the community.
I also recommend that you try downloading the settings again.
You can do this by going to Settings > More > Internet Settings > Accept.
