I forgot how and where how I turned it on.
Every times new messages come in, my phone will auto read them up.
i dont like it so i wanna turn it off. thats all.
Hi @NikX, welcome to our community!
If you have the Smart Connect application installed, open it up and tap the 3 dots in the top right corner > Settings > remove the check mark in the box next to "Text to speech" and your text messages should not be read up automatically anymore when you receive them!
Let me know if that helps!
