- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Headphone problem, keeps cutting out and playing though speakers
Hi.
I have only had my X for under a month. I went to view a youtube video, put headphones on (AKG K451) to not disturb people, and about 30 secs in, it paused. I pressed play again, and the phone played the sound through the speakers, even though the headphones are plugged in.
The headphones work, but the phone seems to reject them. I have tried other headphones, they work fine?? The headphones work fine with my laptop and other devices? Any ideas? I cant be arsed to send it off to get fixed as I've just got it and transfered all my data onto it.
Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Based on your description, there's nothing wrong with your phone, there's nothing wrong with your headphones, just a compatibility issue.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It is not a compatibility issue, it is a problem with the phone. I have this problem with my Xperia X too.
I am using headphones through the 3.5mm jack. If I stop playback and then resume it a short while later (maybe after using a few other apps in the meantime), the sound will come through the speakers, rather than the (still attached) headphones.
Please fix!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the same probleme too , with beats by dre , all of this seem to have start off when I did the last android update 7.0 nugat, what about you guys ? same ? Could be a problem from the android update
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I am also having the same issues and have found the following:
* When listening to music through Google Play Music the headphones disconnect when screen turns off, the headphones need to be reset before they are recognised again
- this happens with Bose QC20 but not B&W P5's
- It is definatly a software issue but unique to specific hardware models
- When using SoundAbout you can overcome the headphones switching off but you need to manually switch when you want a different output
Cheers.
