Thanks so much, I bought my in Amazon as well so I guess its from the same seller. I'll just get the apps you suggested and fix the problem. Thanks so much for the detailed reply.
Hey everyone, having a problem here. The stock Contacts app won't let me open any contact let alone call them. Tried using Xperia Companion, Safe Mode, Factory Reset, and got nothing. I know it's not the SIM card because I took it straight from my Z2 and put it into the X Performance. It's back in the Z2 because it's the only one working. I get that this is the international version, guess the U.S. isn't part of the world. Unlocked with t-mobile if that helps. Please fix this before I have to switch to a HTC 10.
