I face the problem when i playing a game downloaded from play store, it will hang and restart after a hours i play it, is that anyone face this problem as well?
Hi @chan89,
Welcome to the community,
Sorry to hear about the game restarting. I would first suggest checking the developer's website or feedback section, this could possibly be an issue they have at the moment. You may also want to supply them with feedback regarding this type of issue so they can take action to try to rectify it.
You can run through some simple troubleshooting such as remove the app and then a reinstall.
Let us know how you get on.
hi jake
Sorry for not describe my problem clearly
after an hours playing , the phone will hang and restart but not the game
i have try the game in my old phone too ,xperia z2 , it never happen
That could still be related to the game, does this happen with this game only or other applications?
it happen to other game too such as pokemon go and hayday, just it less happen than the game (tower of savior) i play
for example i leave the game on until the phone sleep time reach and auto screen off, then after a minute i turn the device on, it normally will hang then restart
i have use the diagnostic in setting , result all pass
I see, sorry to hear that. This could possibly be related to a software problem, in this case, it may be best to backup your handset and then run through a software repair.
software repair using PC Companion
Let me know if this helps.
i have done reset by ur way many times already, from marshmallow to nougat.
btw thanks for hlp, i think i just use back z2 to play the games
i check the heat of the phone when it restart, it's normal, no heat at all, i dont know is it the back cover material can block the heat or is it the cpu is not boosting when i play the games.
my phone model F5122 dual, no root
