The phone is generally good but the signal quality is good in the 2g code I like but in 3g and 4g mode the continuous signal level decreases and increases but it does not reach full level.
Hi @Xperiaxf5121, welcome to the community.
I wouldn't worry too much about how many bars are showing, but do you notice that you are getting calls drop or internet disconnections etc?
Firstly, thank you. Two times the message came from the opposite side. I do not think there is a problem, only the level changes show me the reason to share it with you.
