My GPS settings is automatically moving back to 'device only' mode even if I switch to high accuracy mode as a result my GPS is not working properly.
Only when I changed to high accuracy mode and restart my mobile its working other then that it's not working even if the location is turned on as the mobile changes back to device only mode after some time.
Kindly help in fixing the same.
