So you are NOT downloading the games from the playstore? if not, this is NOT a warez forum.
Warez is a common computing and broader cultural term referring to pirated software (i.e. illegally copied, often after deactivation of anti-piracy measures) that is distributed via the Internet.
Also, doing so put your device at risk.
If you are downloading apps/games from the playstore and you experience issues, contact the game/app developer.
There's NO NEED TO SCREAM.
@zeror325 wrote:
I DOWNLOADED THESE GAMES FROM PLAY STORE, I looked at Internet to find solution and then downloaded from Internet because they didn't run correctly on my phone.
Downloading apps from other websites it's consider warez and this is not the forum for that, also, you could download an infected apk, if the game/app doesn't work from the play store, you shouldn't really try to get the apk, unless you are testing an older version of the free game/app but still it has risks.
