In the photo there are green stripes on the side of the flash. Is it a malfunction or unreasonable construction?
I also have this annoying issue. In complete darkness, if I capture a pic with fill flash there is a considerable amount of greenish flare. I am sure it's not normal. 😞
@Strampke
Yes I did. But aren't the flares mentioned in those links from external sources? In my phone it happens because of phone's own flash light. Isn't that unacceptable? 🤔
Try to figure out what is the cause.
Read carefully, change circumstances to find out how to eliminate the flares and you will have successful photos afterwards.
+1. date of assembly 11-2017.
