Добрый день. Подскажите, не работает отпечаток пальца в телефоне Xperia x performance. Полностью исчезли настройки о нём. Сброс до заводских настроек не помог
Good day. Tell me, the fingerprint does not work in the Xperia x performance phone. Settings about him completely disappeared. Resetting to factory settings did not help
-GT
Hi @Viktor03, sorry to hear about this.
Your post has been translated English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
The first thing I would advice you to do if you can't find the option is to clean the fingerprint sensor from any kind of dirt or moisture using a dry cloth, remember to restart the phone afterwards and see if you can access the fingerprint manager by tapping Settings > Lock screen and security.
Another thing you can try is to restart your phone in safe mode. All apps downloaded from Play Store is temporarily deactivated in this mod and by doing this you can see if a downloaded app is causing this. For more information on safe mode and how to use it, please click here.
If the fingerprint manager is still missing in safe mode I suggest that you try to perform a software repair using Xperia Companion and a computer. Just make sure that you have made a backup before performing the repair since the repair will erase all user data.
If none of these measures manages to bring the fingerprint manager back I suggest that you contact your local support team in order to have the phone sent to an authorized service center. If you have any questions regarding the service, such as routines, warranty and consumer laws, these type of questions are best answered by your Local support team as well, as they vary between markets.
Try these measures an lett me know how it goes!
