This problem has been starting some time ago. I used stock firmware and for year everything had good.
I've tried to:
-factory reset
-re-install stock firmware from PC software for Xperia
-custom firmwares
When I intalled custom frimware Fingerprint worked god about a week and than again "Fingerprint hardware not available" (but it works after reboot).
Right now when I'm goint to Service Menu to Fingerprint test there is a message "Service Menu has stopped".
I'm tired of this problem. So pls somebody help me.
when you say custom firmwares are you referring to Custom ROMs (unofficial firmware) or are you referring to firmwares from different countries? if the later then try again with the global generic.
I used global official ROM for a year from the moment when I brough XC from the store (I'm not from US so my XC was already for fingerprint). From the moment when problem started (on the global official ROM) and re-install didn't help (I had tried it by Xperia Companion and Flashtool too) I'm using unofficial firmware, but arter a week fingerprint hardware's problem started againt and only reboot is helps (and it works for whole or half of a day).
I've read a lot of forums and treads about this problem but still can't find the solition. I thought about some software compatibility problem (like software which can use fingerprint for entrance, Google Pay for example) but once when I re-installed (official) ROM I got "Fingerprint hardware not available" after the first lock screen (so I even didn't have time for setup any third party software).
Is there a service test for the fingerprint sensor? I don't see one on my phone, but I am using the USA firmware, so it may not be present. Try *#*#SERVICE#*#* in the phone dialer.
I've mentoined it in my first post, so when I'm going to Service Menu-Fingerprint Test I'm seeing "Service Menu has stopped", but the other tests are working good
What about the fingerprint test in the Support App on your device?
Could you tell me you mean Settings-Support-Xperia Tests? If the answer is yes, there are a lot of tests and each passed good except GPS (I don't know why, сonsidering that's works good) but there isn't Fingerprint test. So the only one test which I can see it's test in Service Menu (*#*#7378423#*#*), but as I've written Service Menu is falls off. Vicious circle
If you're unable to use the service test, and you've already reset the phone but the problem still persists, then I would say it's probably a hardware fault. You'd have to decide whether to repair the phone or replace it.
I think I'll refuse to use Fingerprint sensor when I'll completely tired reboot my XC once a day, lol. But could you tell me does Fingerprint sensor has an official item number or something else? I've found some on Ebay but I would know that this is the right one.
Did you find the fingerprint test in the support app? (not the service menu, the app)
