Just arrived, hope it has all the fixes we need.
Someone knows if is possible to find the chancelog?
34.4.A.2.19
I am also getting update., Not yet installed due to battery %.
Once updated, I'll tell you!
That's great news!
Although NOBA is still on Nougat and waiting.......:smileysad::smileycry:
I just installed the update, and my phone are charging battery, after that I will test it and make some feedback with my opinions about this patchI my opinion it's the same problem with Battery life in only 2 hs. I lost 36% with 3 short call's and reading 2 messages.... I thing it's not solved at the moment.
light sensor seems to be fixed
