Hello,
My phone says XQ on it, but I couldn't find that option.
Here's the problem:
I have 2 wifi networks in my house. If I notice my phone is on a weaker network, and click on the "Internet" widget to select the stronger one, I get a white screen, and the phone freezes. I usually have to restart the phone to resolve. How do I fix this?
Thanks in advance.
jny0
Hi
Make sure that your phone is up date and you can try the steps here as well: http://bit.ly/3Bh4B7U
Also, if you have any SD card inside the phone , try to test without it and check if the same thing will happen.
