settings > location > is it set to high accuracy?
settings > about phone > diagnostics > test > test GPS
Hi @sebolicious, welcome to the community. I am very sorry to hear you're experiencing this issue :(.
In addition to uliwooly's suggestions, are you able to try another SIM card in your handset?
Greetings,
As it turned out its not really an error of the smartphone itself but a combination of unfortunate events.
I have a kind of old provider plan that only allows me to use the 3G connection. The smartphone was set to preferably connect to the 4G net, but since I don't have that in my plan it couldn't. There is a menu in the settings where you can set the preferred net. After changing that everything works.
Greetings!
