x
Connect to 4g when no wi-fi
Seagull24
Visitor
Why doesn't my phone connect to 4g when there's no WiFi available? My Samsung did!
2 REPLIES 2
XDevNima
Visitor
Hi
To use 4G go to this way:
Settings > more > mobile networks > preferred network type > select LTE, WCDMA, GSM
By this type when you are at a 4G area your phone go to LTE automatically.
Good luck
Jonas
Master
Hi @Seagull24, welcome to our community!
What @XDevNima suggested is a great way to make sure that the phone is set to use LTE when it's available!
You will also have to download the internet settings from your operator in order to able to use LTE/4G. You can do so if you go to Settings > More > Internet settings, accept and wait for the settings to be downloaded and installed in your phone, once they are installed, reboot your device!
Let us know how it went! Slightly_smiling_Face
