Hi Community,
I want to suggest, in this project, a litle but most nicely UI improvement: colored icons for the shut down, reboot and take screenshot options.
Like the Setting menu, also this one will be more and more beautiful and personalized with colored icons becoming less "stock" and more Sony's UI.
the things is, Xperia UI is appraised because of being near stock,'
however you can write an email to sony as a feedback here: Local support
Your post was removed because it violate the forum guidelines.
http://talk.sonymobile.com/t5/Welcome/Discussion-guidelines/m-p/349678#U349678
Respect is the Key
Are you referring to something like this?
Also, if you have Android concept you should have an option to send the feedback directly to the devs (Through your Xperia)
Thanks for the feedback!
As @uliwooly mentions, please send this as a report to us via the inTouch application.
@uliwooly
Exactly, I refer properly to something like your screenshot! :smileysmileythumbsup:
Thanks to have report an image to better understand what I means.
@Android-Concept-Team
Sorry, but I don't have the program.
However I think my request is the same of more users and it is a little frustrating don't have a dedicated community for all where send feedbacks and little UI improvements like this one.
This my suggestion is not against Google policies, Samsung on the S4 have done it, and should be a nicely improvement for the beautiful Xperia UI.
Thanks for the attention.
