I can't charge my phone. Before the warranty expires I had the same issue. The phone got fixed by Sony. Now I have the same problem after 3 months
Assuming you have tried different chargers and cables, and nothing works: You could have some debris in the USB-C charging port. See if you can blow it out, or use canned air. If not, the port may be damaged, and would require replacement.
