Hello, I recently own a Xperia Xa phone from then little is a phone of my work.
I received a case with window that is not NFC, so impossible to do automatic detection of it.
Can we do manual recognition and not NFC? Because on the case I do not have the logo.
Thanks
Hello again!
If you buy a case that is made by a third party I'm afraid that you will have to contact them for support regarding how to pair or how it interacts with your phone, I will only be able to assist you with cases that we have made.
We have no Style covers for the Xperia XA that you can connect using NFC and there is no feature in the phone to interact with covers that you can't connect using NFC or any other mode.
Hi @benett68, welcome to our forum!
Glad to hear that you bought a Xperia XA!
Which case are you using together with your phone?
There is no feature in the Xperia XA to enable any interaction with a case and we do not have any case for Xperia XA that you can connect using NFC.
Let me know if that answers your question!
Thanks for your mesage but when I see that on the internet there are loads of cases for xperia xa that they not the NFC logo so I hope someone has a solution for it to work.
I use my phone as part of my job as a store buyer.
Hello again!
Thank you Jonas for your answer, I only have to buy a case from Sony.
Thank you for your help and spend all and all a very merry Christmas.:smileysmileythumbsup:
No problem at all.
Happy holidays to you as well!
