I would love you guys bring back a feature it is dumb I know.
Before an old update: To unlock my phone I had to press 4 digits and it would automaticly unlock and now I have to press the check button after the numbers wich I find stupid. I have owned Iphone before and they used it too i do not know why you guys removed it also I almost dropped my phone to press that check button after the digits because I wasn't used to.
Hi @Dvd103,
I have the Xperia X here, and it doesn't have a 'check' option after the PIN, I just press the last digit and it unlocks.
What version of Android are you using?
Hi, today I use an experimental update I think. But it's basically 7.1.1 from Sony. I tried the experimental update expecting this "check thing" to be solved but no. Also It is a Finish version of the phone and I use it in North America right now maybe it is because they get different updates In Finland I don't know... Thanks for replying.
Joined a picture of "about this phone" section of settings to confirm the number you were asking .."About this phone"
