After Updating my Xperia X to 7.1.1, the bluetooth Volume can only be adjusted between two Levels on the whole slider! It jumps after the first approx.
20% from left scale of the slider to a higher level.No further change of Volume on the remaining 80% of the slider. With 7.0.0 everthing was fine like on my Xperia Z2 tablet.
After a little more testing, i figured out that this only happens when it is connected by aptX, normal streaming to a JBL Go allows fine Volume settings 😞
