Since update to Android 8 on my Xperia X whilst I can play music on the car system via Bluetooth I cannot fast forward or repeat tracks using the cars buttons as I could before the update. Any ideas?
I have exactly the same problem, with the music application or with spotify....
Please help
If you don't try you won't know.
There is an old trick that helped some people before.
Don't know if it applies here, but you can try it.
