I keep geting a messages saying Bluetooth is Constantly ctashing
Bluetooth is rather vulnerable for whatever changes.
Give it a new chance.
Either goto settings-apps¬ifications- tap 3 dots- show system- scroll for bluetooth- go Storage- clear cache & data
Or goto settings-system- reset options- reset network settings
Tell us please if your problem is solved by this bluetooth resetting one way or the other.
I've tried to clear cache and data, will let you know what happens. Thanks!
The thing is it crashes when Im not using it. It works perfectly when i do use it!
