I have passed a full 24 hours without disconnection.... before it lost connection every 3-4 hours
after 40 hrs, problem is back
Did you guys notice the memory leak problem when the bluetooth failure happens? I've noticed that when I loose bluetooth connection and can't turn it on again, the memory starts to decrease until it is impossible to use the phone and i must reboot it.
Moreover, my build number is still 34.1.A.3.22 and there is no update available..
Hi all,
I just got my new Xperia X Compact and immediately faced a similar issue.
It doesn't seem anyway to be random in my case.
I have my phone paired with my car's BT. Everything works fine and the connection is stable.
As soon as I press the voice assistant button on the steering wheel (BMW) the phone BT switches off and doesn't turn back on until I reboot the phone.
I'm using the same with iPhone (Siri) and other Android devices (also an Xperia Z3C) and usually I'm then able to use Google Voice assistant to make phone calls while driving without taking the phone in my hands.
I tried already 3 times with the X Compact and got the BT disabled. As I said, it's not random in my case.
I also have a Garmin smartband paired in the meantime (no Android Wear. just Garmin app), but usually the connection is stable.
Hope it helps
Today I have issues with the phone disconnecting from my car's BT while doing phone calls.
It's almost unusable for me like this.
Hope the fix will come soon otherwise I'll have to sell the X Compact and go back to Z3C
