Hello,
Would anyone be able to advise me on the best settings for the best picture please?
I’ve had issues when trying to watch sport, but found that if you have the display settings on ‘Game’ it tends to sort it? The problem is there is that many other settings, which ones are found to work best?
For example the realistic setting? Can’t really see much difference with it being on or off lol!
hello @elthomp0777
what device are you using?
if you go to settings>Display> image quality settings. the different options are explained. some of them like the creator mode, only sometimes kick in in certain conditions like opening netflix or viewing a video
It was just settings like a Realism Creator? It’s set on Manual 10 on my tv? I’ve got a 55inch 8096 model.
I believe there is no perfect answer here
you can always play around with picture settings until you find the best one for you.
It all starts with some basic rules.
Take a look at Sony Xperia Youtube Channel to find more.
